Corps Papillon
Corps Papillon
Messagepar danuel » 01 PMvMer, 29 Sep 2010 15:01:21 +000001Mercredi 2009 040340
My name is Daniel and I am Portuguese. Sorry I do not know write in French but I talk with a moderator. :(
I have a engine OM616.934 and I don't know "Corps Papillon" works.
When I accelerate Open two Valve/Covers (I do not know the correct name) But when decelerate only one close the other Do not close. I think something missing.
Merci.
PS: that is the corps http://www.ptp-images.com/affiche-direc ... 36e76.html
Mercedes L406DG - http://youtu.be/fyrsEUCbUfI
Donate to Merciana with Bitcoin.
BTC Address: 13Qs5NQQNBGn4eQBnVXVLvN6kqSzm2rcsb
danuel
Inscrit le: 01 PMvMer, 29 Sep 2010 12:42:14 +000042Mercredi 2009 041240
Re: Corps Papillon
Messagepar ram » 01 PMvMer, 29 Sep 2010 15:07:21 +000007Mercredi 2009 040340
no problem danuel, welcome here ;)
I think someone will help you here !
:arrow:
J'ai un moteur OM616.934 et je ne sais pas comment marche le "corps papillon" (traduction littérale ?)
quand j'accélère ca ouvre 2 valves (je ne connais pas le nom exact) mais quand je décélère, une seule seulement se ferme, et l'autre non.
Je pense qu'une pièce manque
ram
Re: Corps Papillon
Messagepar danuel » 01 PMvMer, 29 Sep 2010 15:15:11 +000015Mercredi 2009 040340
ram a écrit: ... "corps papillon" (traduction littérale ?) ...
I found in google the item and google indicated to me the name Corps Papillon, I don't know the correct name for this item.
danuel
Re: Corps Papillon
Messagepar ram » 01 PMvMer, 29 Sep 2010 15:23:07 +000023Mercredi 2009 040340
no problem, I suppose the pros will understand with the picture ;)
ram
Re: Corps Papillon
Messagepar toma » 01 PMvMer, 29 Sep 2010 16:41:31 +000041Mercredi 2009 040440
What? you tell that "Ram a un corps de papillon" ????
toma
Re: Corps Papillon
Messagepar ram » 01 PMvMer, 29 Sep 2010 17:32:54 +000032Mercredi 2009 040540
please toma, don't mess this thread !
...and yes, of course I got a butterfly body ! :mrgreen: :mrgreen:
ram
Re: Corps Papillon
Messagepar danuel » 01 PMvMer, 29 Sep 2010 18:23:35 +000023Mercredi 2009 040640
In Portuguese it's "Corpo de Borboleta" translate in English "Butterfly body" in French "Corps Papillon" :)
Font: Google Translate :lol:
danuel
Re: Corps Papillon
Messagepar ESTONE » 01 PMvMer, 29 Sep 2010 21:32:46 +000032Mercredi 2009 040940
Vivamente google translate!
Tomorrow I give you an answer.
Be patient...
Si c' est une soi-disant bonne affaire il faut trouver pourquoi!
ESTONE
Inscrit le: 01 PMvDim, 05 Sep 2010 15:29:27 +000029Dimanche 2009 040340
Localisation: Niort (79) en ce moment depuis un moment mais plus pour longtemps...
Re: Corps Papillon
Messagepar ESTONE » 01 AMvJeu, 30 Sep 2010 10:22:08 +000022Jeudi 2009 041040
D'après ce que je comprend c'est les clapets d'admission non?
ESTONE
Re: Corps Papillon
Messagepar danuel » 01 AMvJeu, 30 Sep 2010 10:36:24 +000036Jeudi 2009 041040
Connection from outside to inside.
Oil Filter - Tube - Butterfly Body - Intake manifold - engine
**Translate google**
Connexion de l'extérieur vers l'intérieur.
Filtre à huile - Tube - "corps papillon" - Collecteur d'admission - moteur
danuel
Re: Corps Papillon
Messagepar ESTONE » 01 AMvJeu, 30 Sep 2010 10:40:14 +000040Jeudi 2009 041040
Follow this link:http://62.147.175.53:8080/RTA/index.php.
Be patient this afternoon, i tell you the problem and maybe the solution
ESTONE
Re: Corps Papillon
Messagepar tipierre » 01 AMvJeu, 30 Sep 2010 11:10:30 +000010Jeudi 2009 041140
danuel a écrit:When I accelerate Open two Valve/Covers (I do not know the correct name) But when decelerate only one close the other Do not close. I think something missing.
Hi danuel
All is all right, the first valve adjusts the quantity of intake air and the second is not really a valve but just an abutment (no other office), then it is normal it does not close.
It must be like that, there's no problems :D
bye
Re: Corps Papillon
Messagepar danuel » 01 AMvJeu, 30 Sep 2010 11:23:23 +000023Jeudi 2009 041140
ESTONE a écrit:Follow this link:http://62.147.175.53:8080/RTA/index.php.
Thanks I take a look :)
tipierre a écrit:All is all right, the first valve adjusts the quantity of intake air and the second is not really a valve but just an abutment (no other office), then it is normal it does not close.
I thought the new part was also damaged because the second valve is not closing.
I will try and reply something. :)
Merci Beaucoup ESTONE et tipierre
PS: I learning French in this forum :D
danuel
Re: Corps Papillon
Messagepar ESTONE » 01 AMvJeu, 30 Sep 2010 11:27:10 +000027Jeudi 2009 041140
It's a start! ;)
ESTONE
Re: Corps Papillon
Messagepar danuel » 01 PMvJeu, 30 Sep 2010 21:14:13 +000014Jeudi 2009 040940
Well!
My Star and already has a heartbeat!!!! :D :D :D :D :D :D :D :D :D :mrgreen: :mrgreen: :mrgreen:
Merci Beaucoup!
Je suis trés content, parce que je suis tr´s content! hehe :lol:
danuel
Re: Corps Papillon
Messagepar ram » 01 AMvVen, 01 Oct 2010 08:16:44 +000016Vendredi 2009 040840
the mercostar conection !
ram
Re: Corps Papillon
Messagepar ESTONE » 01 AMvVen, 01 Oct 2010 10:47:01 +000047Vendredi 2009 041040
Or the real star-system!
ESTONE
Re: Corps Papillon
Messagepar ESTONE » 01 PMvVen, 01 Oct 2010 14:49:09 +000049Vendredi 2009 040240
It's confirmed that it's normal the second has to remain opened a little more half.
If it was closed there would be more air.
Tipierre is right!
ESTONE
Utilisateurs parcourant actuellement ce forum : Google [Bot] et 11 invités
